So after stripping the paint in the hull, I found a slice in the bottom about two inches in length, that looks like it had been repaired by indenting the area, and filled with what looks like 3m 5200. I would like to get that and a few other spots welded. What should I expect to pay to have that and a small patch about 2x2" square welded?
I have a bunch of loose rivets. Do I use 5200 on the outside, or Gulvit on the inside, or both. I am not sure the best rout to take here.
Thank you.
Thank you.
