Loweman
The plastic floor/deck drain in the console area of my 2000 Lowe 170 bass boat broke/cracked. I removed it for the replacement I got and am amazed that there is no visible drain tube or opening for water to run into the bilge. I just have a four inch wide opening that is about 3 inches deep down to what appears to be the hull. The round wall of the drain hole is unprotected foam sandwiched between the aluminum deck and the hull.
There's a slight groove in the base of the "drain", but nothing evident like a drain hole/tube/hose...
I've had a couple of inches of water in the console area before (can you say no plug and/or livewell overflow?) and the water cleared out fairly quickly with the bilge pump kicked on.
I did a quick test with a small cup of water poured into the open floor drain and it just seemed to very slowly drain through the foam wall in the drain hole. Is this a normal floor drain "system"?
What am I not getting here? Anyone else replaced a similar floor drain and know what I'm talking about?
Photos are attached to better explain my question. Sorry close up photo is blurry. Thanks.
