fused switch panel - trying to make a decision
franner11
Nashville, TN
Hey guys!
I'm pulling all my electrical stuff together for my 1542 tracker mod, and I'm having a really hard time deciding on a switch panel...
That said, I understand basically how I will be connecting everything, but I was wondering if I could get a little input on which switch panel is best. I want to do this right, the first time, and have possible expansion switches available for adding other electrical items in the future, with ease.
So, I have two deep cycle batteries - one will be trolling motor only and the other with have all of my other components hooked up to it:
bilge pump
bow fish finder
stern fish finder
bow/stern running lights
cig lighter
possibly a cockpit light or two on the same switch (think 2 led lights)
I was planning on having the bow & stern nav lights on the same switch, but I understand that if anchored, I'd need to have just the stern/anchor light on and not the bow light. That makes me think I might need to either get a three way toggle switch and replace that in the panel I buy, or run them on two separate switches (which I don't really want to do), or have a totally independent 3-way switch separate from the 6-bank switch panel.
Anyway, I'm trying to decide which panel is the best, and would welcome any advice from y'all:
This for $100:
https://www.amazon.com/gp/product/B000K2O0B8/ref=ox_sc_act_title_1?ie=UTF8&m=A1UNWS4MSNTF2A
or this for $70:
https://www.amazon.com/BEP-CSP6-Water-Proof-Panel/dp/B000NI3GV4/ref=pd_rhf_dp_p_t_2
What do you all think? Or am I overspending and should keep the BPS one I already bought (which seems on the mega-cheap end):
https://www.basspro.com/Bass-Pro-Shops-Rocker-Switch-Panels/product/861/100219
Thanks!
Fran
The two switch panels that you linked to are made by Blue Sea and Anchor, both heavy hitters in the marine industry for many years and you will never go wrong with any of their products. The BPS appears to be very similar in materials and construction to those made by Sea Dog. They have also been around a long time, but they manufacture low end parts and equipment for casual boaters. I personally do not recommend their product to my customers. Just my personal reference after having been in the business for a few years.
With the Nav lights, there are a couple of ways you can go.
One is to utilize two of the switches in the panel if you do not have them already designated for anything, and put the bow light on one switch and the 360 white light on another and turn on one or both as needed. That's not my first choice either. but that's preferable to having an extra switch installed somewhere else just to operate lights.
If you go with Blue Sea or Ancor, they probably make a DPDT or a SPDT switch that could be installed in the panel. With a DPDT, you can wire the switch to operate one or both lights easily. A call to their tech support people will tell you what you want to know. It's just as easy with a SPDT but you have to use a diode at the switch, easy and available at Radio Shack.
I wouldn't bother to run the cig lighter plug off of a switch. There's no need to switch it on and off. Just run a #10 wire from your hot buss and fuse it with a 10A fuse. That's what the cig lighters are rated for.
Thanks so much, Bob - great advice - especially on the cig lighter.
One more question - if I get either the Blue Sea or Anchor, I still need to get a separate bus bar for negatives, right? Or are those pretty much built into the switch panel already?
Actually just called Blue Sea - great tech support. I do need a separate negative bus bar if I get the 4376. And a DPDT switch to swap out in one of the positions for the bow/stern lights is part # 4155.
Again, Bob, you rock!
Thanky!
~ Fran
Give some thought to what the main items you will be powering from the cig lighter, and how close it is to your position. You may want it switchable (for convience) from the panel. I mainly use mine for minnow bucket airator, portable live-well, or extra night lights. I prefer to use the panel switch vs pulling plug or finding the inline switch, etc.
The two FFs can be powered by one switch or just inline fused. They have to be powered on at the head unit anyway. Powering modern units off via ext switch can bypass some of the shutdown routines, too. You can loose some settings changes and some gps data.
I'm only thinking of installing the cig lighter for an emergency cell phone charge...or a spot light if I ever go out at night (which is doubtful). Just really wanna have the option to charge something if I need to, or have the option to have an outlet on hand if needed it for anything else.
I will be installing the cig lighter separately and not on the switch panel, as Bob suggested, and it will be right next to the switch panel, within reach of the stern seat where I'll be steering my tiller controlled outboard. :)
I just like to be prepared, obviously. You just never know being out on the water!
And as for the bus bar...anything wrong with a 10 position 150 ampere version?
https://www.amazon.com/gp/product/B000KOR7DE/ref=ox_sc_act_title_1?ie=UTF8&m=A1UNWS4MSNTF2A
The 150A buss bar will be fine. That lets you run a heavy wire to it from battery neg and than attach all of the grounds from your devices to the bar putting all of the grounds together. I think some switch panels may have ground bars, but if they do, they will be small and difficult to work with when you start attaching multiple leads to them. Plus, there's no need to since you are only switching 12V.
I hadn't thought about losing the shut-down routines on the FFs, but that makes sense. There's no need to run them off of a switch anyway. Go directly to your fuse block and come off of it with a 3A inline fuse or whatever the manufacturer says to use and all is protected.
I think you are on the right track. Electrical is one area where it really has to be right and you can do that either the first or the second time. Nothing disrupts a fun day on the water, or a trip home faster than an electrical problem. 12V stuff is really simple and if you do it right, you'll never have to worry about it again.
Thanks - I think I understand what y'all are telling me now. I'll draw up a diagram of my plans once it all sinks in...
So what I am thinking now is this...
Battery 1 + wire to 30amp (or 45amp) circuit breaker to 6 bank fused panel using 6awg on both sides.
6 Bank fused panel contains:
Bank 1: 10awg to Bilge Pump
Bank 2: 16awg to 360 stern + red/green bow lights on one 3-way toggle switch
Bank 3: 16awg to Running lights - 2 LEDs on same switch
Bank 4, 5, 6: not used, but available for future expansion
All banks running same awg wire to negative bus bar, then bus bar to negative on batter 1 using 6awg.
When you say to run my two fish finders to the fuse panel...I don't understand. If you're saying not to have the fish finders on switches because it'll erase any settings etc...are you just saying run them straight to the battery in a circuit with just an inline fuse and not to run to or from the fuse panel at all? I don't have any other fuse block...so I guess that's what's confusing me...
Attach the wires for the fishfinders to the point that feeds 12v to the switch panel and put the inline fuses close to the attachment point. That will be the most convenient and you'll probably have the ground buss close-by. I hate to see a nest of wires attached to a battery terminal. Aside from looking sloppy, it can be a hassle if you need to change batteries. I've had to trace down a lot of problems because some boat owner just used whatever color wire he had in his tool box and attached them wherever possible.
On the FF's you can run them on their own circuit back to the battery, or from the panel power bus/grounding bar. As long as the inline fuse is within 6-7" of the + connection, it will be fine. For saving on wire, you might run one from the panel + and the other right to the battery.
Also, 10ga seems quite large for a bilge pump, but don't know the current draw and distance for yours. My Rule 500gph is only 1.9A draw, and recommended fused at 2.5A.
IMHO, if you have the switches, use them. If you need to change in the future, then you have the options of taking the cig lighter and ff off the panel switches. I thought you were trying to get the panel size down or were short switches.
Got it, guys - thanks so much!
I'll post a diagram when I get it all sorted out. I really appreciate your help!!!
...was guessing on the 10awg for the bilge - I'll check the paperwork and use the correct size. :)
OK guys, here's my layout.
Here's what I am guessing I need in regards to wire size and the connections of everything.
I welcome comments and/or suggestions...
Battery 1 setup:
Battery 1 +/- goes to circuit breaker with 6 awg wire (30amp 40amp or 50amp CB?) then 6awg + to fuse panel & 6awg negative to bus bar.
Negative bus bar connects to negative on the fuse panel using 6awg.
All negative lines from every component (bilge, ff1, ff2, LED series, nav lights) go only to negative bus bar using either 16awg or 14awg, depending on the distance to the negative bus bar.
All positive lines from every component go to their respective switches on the fuse panel using either 16awg or 14awg depending on the distance to the fuse panel.
Cig lighter negative connects to negative bus bar using 10awg wire.
Cig light positive connects to fuse panel (but not a switch) positive using 10awg with a waterproof inline fuse of 10amps.
What size circuit breaker that will need to go between battery 1 to the fuse panel. Is 30 amps OK? 40 amps? Should I get another 50amp like the one on the trolling motor connection, or is that too high amperage?
Battery 2 Setup:
I think I have the trolling motor connections all set, but have one little question: battery 2 goes to 50 amp manual circuit breaker which goes to trolling motor outlet plug. Only question I have is that the outlet plug has 8awg wire on it, but I thought I needed to connect all parts of the circuit with 6awg. Is 8 awg all around OK?
Do I have this right?
Thanks in advance!!!
Fran
also, just as a layout note, I will be putting in decking with carpet, etc, similar to this build by Hooky1420...so my boat won't be bare bones like it is in my diagram.
https://www.tinboats.net/forum/viewtopic.php?f=21&t=16300
First off, I am by no means a wiring expert. I am in the middle of my wiring/electrical hook ups.
For your battery 1, a 50 amp circuit breaker should be fine, hopefully. That is what I decided on. Others suggested a 30 amp, but I just went with a 50 to be sure.
For your battery 2, 8awg should be okay. That is the consensus I have gotten from most of these posts for trolling motors. Plus since you're not wiring it a great distance, 8 is fine. Just my thoughts.
I'm no expert either, but here's few comments / questions:
"Negative bus bar connects to negative on the fuse panel using 6awg." Not sure what you mean here, you don't normally need to connect a ground to your fuse panel, unless your panel needs a ground for the switch's light circuits.
"Cig light positive connects to fuse panel (but not a switch) positive using 10awg with a waterproof inline fuse of 10amps." If you're connecting this to the fuse panel, then you don't also need an inline fuse...just fuse it at the panel.
"What size circuit breaker that will need to go between battery 1 to the fuse panel." It looks like your total draw thru the fuse panel is 20+ amps, so a 20 amp breaker would do it, assuming your run to the panel is under 10'. If your amp draw is more, your breaker may need to be higher.
"the outlet plug has 8awg wire on it, but I thought I needed to connect all parts of the circuit with 6awg" Agree with Chitown, for that short of a run, 8AWG should be ok.
I couldn't exactly tell, but from the diagram it looks like you're running a lead from the battery 1's circuit breaker to the negative buss bar. There's no ground for the breaker, it just goes: battery+ to breaker (within 7") to fuse panel. The breaker posts should be marked for battery and load (panel).
Appreciate all of the advice, Chitown & RivRunR!
The fuse panel I bought does have lighted switches, so I will be running a negative line to it from the bus bar.
And thanks for clarifying the circuit breaker not having a negative on it - just positive - makes sense.
As for the cig lighter line...still a tiny bit confused about that....Mr. Landry said not to run it on a switch but as stand alone with an inline fuse. (Just run a #10 wire from your hot buss and fuse it with a 10A fuse.)
What's the hot buss? The positive bus in the fuse panel? Or the battery + ?
Maybe there is some semantics confusion here: I bought a fused switch panel with switches inside of it, so it's all one tidy box. I do not have a separate fuse panel box from a switch panel box - it's all one thing.
This is what I bought: https://www.amazon.com/gp/product/B000K2O0B8/ref=oh_o00_s00_i02_details
If you have a positive bus, run the cig lighter to it. If not, run it to the battery. Either way it'll be going to the same place (battery), but having all your connections going to one bus helps you trouble shoot when something stops working.
Wasn't sure about your switches, but since they are lighted then it makes sense that the panel has a ground.
On the cig lighter... I was just going on your "Cig light positive connects to fuse panel but not a switch" comment. Landry is right, you don't need it on a switch. I thought you were fusing it at the panel AND with an in-line, and you don't need both of those fuses. You can just go with an in-line fuse to either a positive buss, or to directly to the battery. A positive buss is the same type of distribution bar as your neg buss, only with a + lead feeding it. But it doesn't look like you need to get one since the only thing (?) connected to it would be the cig lighter. So, short answer?...cig lighter with an in-line fuse directly to the battery1 +.
