Beefer
I tend to be a bit long-winded, but it gives you the whole picture, so bear with me....
I have a '59 Johnson QD-20 10hp on my tinny. The first few times I took it out, she cruised right along, with a max of 21mph. Problem was, she would die at idle, and the needle valve wouldn't adjust anything. I figured I need a cleaning/rebuild. On Wednesday, I wanted to go out, and I threw a full can of seafom into about 5 gals (6gal tank). Well, (I'm guessing) this caused a loss of power because of the high ratio of seafoam to gas, and I could no longer get up on plane (6-8mph WOT), but the low end was running a bit better (still wouldn't hold idle). So I succumbed to the fact I need to do it right, and actually tear the carb down, clean, and rebuild. Last night (Thursday) I did this, and got a decent amount of crud out. Today, I re-assemble everything, and add 4 gals of fresh gas to the remaining seafoam mix (about 1.5 - 2 gals). First thing I noticed was it wouldn't start in anything but full throttle (I attributed that to the carbs needing adjustment).
So now I have her running in WOT, trying to lower the rpms, but she keeps stalling out if I come off full. In the high speed needle seat I have 3 packing washers, and also 3 in the low speed. I originally only put in 2 in each. Now there are changes when I turn them, but I still can't come off full throttle without dying.
So my first question is - could the seafoam mix be affecting the runabilty that much?
Secondly, if it's not the seafoam, where should I be looking?
Unfortunately, I only have one gas tank to run off of, otherwise I'd try fuel without seafoam.
