chrispbrown27
Picked up a trash can today to run the motor in to mess around with it at home. While standing back and watching it run I noticed two holes on the inside, toward the boat, around half way down the motor. While it was running these two holes had water shooting out of them...is this normal? I took a little video of it in case you guys don't know what I am talking about. Also, if you notice, the plate that you remove to access the shift linkage is leaking a small amount of lower unit lube. Would that be a gasket that has gone bad? And is this normal? The motor is a 1972 Johnson 25 horse.
Chris
Chris
