Ok short version.. does the amount of water coming from the two ports at the base of the cowling look normal?
Longer version... Got ready this spring and hooked up the muffs to check it out and it wasn't pumping water. No problem I know it's due an impeller as it's been 3 years since I got it and I haven't done it yet although the seller said it was just done before they sold it.
I ordered it and replaced it and due to life and the fact a friend got a new boat and we were taking his a lot I didn't get the lower unit mounted back until this week.
Now I put the muffs on it and it's not building any water pressure. (I installed a water pressure gauge before I ever took it out the first time) Even at high rpms. Although there is water coming out the indicator and a little out those two ports.
I do some reading and see a lot of recommendations to put it in a barrel. So I do and yay it's working fine but I never noticed this much water coming out those ports before.
Also it used to build pressure when on the muffs.
I can feel when the thermostat opens on the pee water so I'm thinking it is working fine.
I get kinda worried about stuff that could strand me in the middle of the lake. Although my trolling motor can get me back from pretty much anywhere as long as it's not blowing too hard.
