Livewell Plumbing for Aereator
Encoreman
Alpine, Tn.
Hi I have 15' Terry with factory livewell. It has 2 ports riveted thru bottom of livewell and thru bottom of hull. These ports are C shaped, with 1 facing the bow and 1 facing the stern. They have 3/4" pipe threads and that's all I have. I know I can put a piece of pvc the height I want my water level to be, but what about plumbing the aereator? I will attempt to post pic's tomorrow, but forecast is rain.
For the PVC I assume you mean a section of pipe with a threaded coupling so that the water doesn't drain. Does this need to be on both ports or just the stern facing, "drain", port? As far as the aerator, I'm guessing a small (5/16"?) hole could be drilled for the tube to run through.
