I have a lowrance 4x hdi fish finder i just installed on my 1648 alumacraft. I fish shallow water in the flats a lot and spend a lot of time in the 4-8ft depth range. The ducer is transom mounted between two strakes and 3-4 inches outside the prop circumfrence on the starboard side. it then runs up the side and into the side where some 3" plastic conduit contains all of my wires. the ducer is roughly 1/8 to 1/4 of an inch below the bottom of the hull and is just slightly nose up. The sensitivity is auto set for 56%, and I am worried if I go any lower I wont be able to pick up the holes and slight cover on the bottom. sorry for the crappy pictures. my phone is not exactly fancy. But any ideas are welcome.
Here is a list of the tests and results i have done so far
Motor on/off-no change.
Neutral/Idle/slow speed-no change
Going on plane then riding-struggles while getting on plane but works fine after the nose settles
Trolling motor on/off/running-no change
sitting still/drifting-no change
Is it normal to get a lot of interference at depths up to 5 ft? I can reduce the surface clutter but that just hides the problem, not fixes it.
