Troutman3000 said:
That does it for me too. So what are you going to do Dave? I have a 99 tracker and all the wood is solid but the carpet is starting to wear. I guess they used marine plywood and it has held up fine for the most part. There are some areas that have some small issues but it has lasted ten years so far. Opinions?
Troutman,
Well, for the transom, I'm waffling between going all aluminum, all fiberglass, mahogany or exterior plywood. I'd prefer a non-wood solution, but the fiberglass has already proved too expensive and I suspect the aluminum will as well. That leaves me with mahogany at $100.00 for the transom or less than $50.00 for two sheets of plywood.
With decks and floors to consider as well and unexpected dental expenses about to pop up, I may be forced to go with exterior plywood. I don't see any major advantage to marine grade plywood if you're willing to coat with spar varnish and seal the edges of the exterior grade with silicone. (This was suggested to me for the transom by Athens Marine, it's what they normally do when they replace a transom.)
So mostly because of costs and because boats, like life, are a set of compromises, the exterior grade plywood is likely to get the nod.
Here's a thought though on your boat: I've seen mentioned in some of the fiberglass forums where guys have used fiberglass resin compounds to repair and "harden" marine plywood that was starting to soften and break down. I'm not sure how effective it is, but it might be worth it for you to look into. Basically sounded like they were saturating the weak wood with a "hardener" and then fiber glassing over it. Looked like it might be a good alternative to replacing the wood.
It's a shame some company doesn't come up with a "plastic/fiberglass cut-able board" for transom replacement purposes. Should sell well. Anybody looking for a business opportunity?
