bcbouy
its so thin it wont have time to heat up or bind before you cut thru it.
fish4thriLLs said:Okay, a work buddy of mine loaned me a hole saw with a couple of "blades" with it, the smallest of which is 1.25" dia. My thru-hull fitting measures 1.0" dia. Would it be okay to go ahead and use this or will the hole be too big for it to work alright? I think it will be okay, but I've never done this before so I don't know for sure how much difference, a 1/4" too large of a hole, will make.
X2 And get a DEATH GRIP ON THAT DRILL when using a hole saw! If that sucker hooks up on what you are drilling, it will take the drill right out of your hands! (experience)Ranchero50 said:For the cleanest cut with a hole saw hold the drill at an angle so only part of the teeth are engaged at one time. As the saw cuts through the metal change the angle so the teeth are pulling through the metal vs. pushing through the metal. If you hold it square you tend to end up with a bigger hole because the thin aluminum will wallow out arond the center drill.
That's why I recommend a unitbit for smaller holes.
Jamie
