bikerider
- Joined
- Apr 18, 2018
- Messages
- 230
- Reaction score
- 2
I have a 12 ft Starcraft that I will be replacing the transom on hopefully this coming winter. The transom dips down a bit from edges to center about 1 1/4" (see pictures). Is there any reason I can't make it level with the back edges of the boat when I replace it? I have a 5hp outboard on it currently. I measured, and if I did make the new transom level, the outboard's cavitation plate would be about level with the bottom of the hull. Currently the cavitation plate sits a bit lower than the bottom of the hull. Is there any reason I shouldn't make the transom level across the back when I replace it?
(The pictures are of the same model Starcraft, but not my actual boat)
