wich is wich?????
shawnfish
OMAHA NE
can ANYBODY give me some input on what makes a V a V, a mod V a mod V, a semi V a semiV? i know a jon boat is a green flat bottom but ive heard someone say this boat is a mod V and other people say its a v or a semi V etc.....
V usually have a V bottom all the way to the back...A semi-V flattens as it goes back.
As far as Mod V its a Jon boat (flat) style with a V front.
You would have to search to see if there are any official designations, but here is mine:
Look at the bottom of the boat at the transom, it will be flat, or some shape of a V. (sorry not tri-hulls or cats, ;)) A very shallow V is considered a Modified V (mod v). As the V gets steeper, it becomes a "normal" V, and even steeper a "deep" V. At what angle do these switch, can be subjective, and/or varies by mfg. Look at the cross section from bow to stearn.
semi-v: looks like a v hull in the bow, but quickly tappers to a flat style bottom.
Jon boat: flat bottom boat from bow to stearn.
mod v jon boat: A slight point and a shallow v from bow to stearn, but still has the shape of a jon boat.
Here's some examples. A true v-hull looks a lot like the semi-v, but the v bottom goes all the way to the transom.
It looks like some jon boat mfg say mod v for having a pointy bow but taper quickly to flat bottom. I would have called that a semi-v jon. :D
and that would be confusing, so that's why they call it a mod-v :mrgreen:
So what should they call one like mine, that has a v all the way to the transom? A "real" mod v jon? :D
PS: The pic above appears to be a "real" one. The v goes at least to the rear bench. Many brands I've seen do go to the transom.
