danmyersmn
Grrrr, just venting.
I have a water leak in my main "all the hvac crap goes here" room. I first found a pin hole leak in a 1/8" copper line going to my ice maker. I fixed that and thought I had too much water on the floor from it. I dried out the floor and it stayed dry for a day. This morning it was all wet again. The worst part is that it appears to be three different pools of water. I checked every joint in all the water lines in the room and none of them are wet.
I have a fan blowing to dry it out again and I am going to check it every few hours and run just about every thing in my house and see if I can track it down. If I cant do that then I guess its time to hand sheets all over the place and see if maybe the water is not coming from above but below? Maybe my water softner is leaking. Dunno, **** thing!
