Weather and Fishing
Bucks Co., PA
Found a great article and wanted to share:
https://www.chesapeakeangling.com/resources.htm
Weather Factors for Fishing
The Affects of Weather and How best to Deal with Them When Fishing.
We’re all aware of how the weather plays a role in fishing…right? Sure, we all hate it when the weatherman forecasts wind or rain when planning our next fishing trip.
However, how many fishermen really know what affect changing weather conditions have on fish (the way they react, feed and so on), and better yet how to deal with the conditions and still catch fish.
My goal in writing this is to put into laymen’s terms what these so-called meteorological events have to do with going fishing. Well, there is no really simple way to explain clipper systems, warm fronts, cold fronts, isobars and barometric pressure but knowing what affect they have on fish is yet another key to having a successful day on the water.
Your average fisherman just wants to go fishing not analyze the weather so basically if it’s suppose to rain he/she packs rain gear, if its suppose to be breezy… how breezy, is it “it could be a little choppy breezy or small craft advisory breezy. Nonetheless most fisherman just tune into weather channel on TV or their VHF to determine the overall conditions that they need to prepare for.
I like to consider myself pretty observant and try to take into account as many factors as I can that will improve my fishing and for my clients. This includes not just where to fish and techniques but whether or not it’s worth going out or how can I deal with the conditions Mother Nature has dealt me.
Let’s cover some of the meteorological definitions for weather that the average guy has not a clue about.
Clipper System: A fast moving weather sys. Typically referred to as an Alberta clipper. These systems form in the North (over Canada & Great Lakes region) and sweep south or southeasterly at a rapid pace and bring winds, some rain and cooler temps. But generally are quick to pass.
Warm Fronts & Cold Fronts are just that, these are weather patterns that pass through and change the temperature by several degrees up or down. Warm fronts introduce low pressure and usually indicate rain. Cold fronts on the other hand introduce high pressure and are associated with cooler drier air.
Isobars: These bars on commonly used on weather maps along with triangles or half spheres. I won’t go into great detail of all their meanings but for definition purposes they are used to represent wind. The tighter the isobars or lines are together the higher the wind forecasts.
Barometric pressure: This is one of the major factors used in predicting weather. Again, without going into to great detail I’ll just highlight some of the major features. As noted above warm fronts are associated with low pressure (falling barometer) and cold fronts are associated with high pressure (rising barometer). During a warm front the barometer will usually drop at the approach of the front and level off when it passes. The wind will typically shift east-northeast to east-southeast and finally south-southwest. During a cold front the barometer will usually rise and winds will shift clockwise around the compass from east-southeast to south-southwest before the front. Strong gusty winds will often follow behind the front.
This all sounds like a lot of information to remember, well it is but you don’t necessarily have to remember it but rather just how to deal with it as I will go onto discuss.
Fishing in the Rain & Wind
Rainy conditions are typical in the spring (usually March, April and May) and just as the water is starting to warm up it will rain for what seems like days and cool things down again. Heavy rain also over time will freshen the water (decrease its salinity) and in the bay and surrounding tributaries it will often make a mess of the water with run off (cloudy muddy conditions resulting in poor water clarity). Of course fresher cooler water and low salinity send fish a little deeper at times, cloudy to dirty water is not really preferred by any species especially Speckled Trout but Stripers are a little more tolerant. The resolution is to fish deeper and look for clearer water. Fish will often hold on the edge of dirty to clear water and at a thermocline or depth where the temperature and pressure better suit them (we’ll discuss the effects of pressure in the next section).
Wind can be an advantage and disadvantage. Some of my best fishing has come on windy days. Fish tend to like choppy water, lesser species and baitfish are less able to fight strong currents associated with wind and therefore get tumbled in the current or cannot out swim their prey making an easy meal for the fish.
The fisherman can take advantage of the wind which diffuses the water’s surface clarity (making their overhead presence less visible to the fish). A great place to target fish is against shorelines and points where the wind is rolling waves against the banks. This wave action makes these spots prime hunting grounds for fish chasing bait thus making it prime for fishermen as well. The disadvantage on the other hand is that over time the wind can make the water turbid and cloudy sending fish in search of cleaner water in which to hunt their prey. As mentioned above just look for the dirty/clean water line or fish deeper, fish often go to the outer edge of flats or cover looking for clean water and also may hold in potholes or troughs.
Barometric Pressure and Fish
Warm fronts and cold fronts as described above affect the temperature and winds and are associated with low and high pressure. Of course over a prolonged period changes in air temperature will affect water temperature but during the short term they only have a marginal affect or change to the water surface temperature. The real affect during the approach and passage of fronts comes with the change in barometric pressure. All fishermen know that as weather changes it seemingly has an affect on fishing some short term and some longer term.
Well, the reason it affects fishing is explained in barometric pressure or rather the rising and falling of the barometer. Changing weather impacts whether or not we go fishing depending upon how severe the weather but fish are already wet so they don’t’ really care so much if it rains, they like to swim in the waves and current so they don’t care about the wind that causes it to be rough. What fish are concerned about is being comfortable and finding food.
Have you ever heard of a swim-bladder in fish… of course you have. What I bet you didn’t know is that barometric pressure affects a fish’s swim bladder. That’s right; air pressure affects fish under water. Barometric pressure is one of the most talked about but least understood factors that affect the way fish act. Learning why fish eat one day and don’t the next is often the mystery.
Let me explain in a little more detail; first lets address a little scientific data. Barometric pressure produces a lot less pressure on fish than the water does but it does affect them in shallow water. The entire column of air above the earth’s surface is defined as weighing one atmosphere. To move from the surface of the water to let’s say 16 feet deep is also one atmosphere of pressure. The small amount of change in pressure caused by a frontal system is less than the pressure of a fish swimming down two feet. Basically a fish can withstand 10 times any change that barometric pressure causes and the deeper the water the greater the pressure compressing their swim-bladder. Now let’s take a closer look at the biology of a fish. The fish’s swim bladder is a gas-filled sac that controls buoyancy, if a fish starts to descend, the increased pressure from the water results in a compression of gas inside the swim bladder. If the fish swims shallower there is a decrease in water pressure and so the gas in the swim bladder expands. Where barometric pressure comes into play is when the pressure changes suddenly as it does with the passage of weather fronts (warm= low pressure & cold = high pressure) these sudden changes affect the pressure on the fish’s swim bladder (again more so in shallow water) thus making them uncomfortable (due to the expansion of their swim-bladder) and less interested in feeding (or chasing your lure/fly) and more interested in finding more stable pressure found at greater depths.
Is your head spinning yet or is your brain cramped...while researching this phenomenon for facts mine was. Irregardless of whether you understand and can follow all of this data it does in fact offer the explanation of how weather and the barometer (the rise and fall in pressure) affect fishing.
Some general guidelines for dealing with the affects of barometric pressure when fishing are as follows:
Pressure
Type of Weather
Affect on Fish
Techniques/Tactics
High
Clear Skies/Bluebird days.
Fish are slower and lethargic. They hold tight to cover or in deeper water. Don’t expect high numbers.
Slow your presentation. Target cover and deeper water.
Fishing S-l-o-w can spell s-u-c-c-e-s-s!
Rising
Skies clearing and weather improving.
Fish are starting to become more active.
Fish with brighter lures/patterns and near cover/structure. Work varying depths.
Normal to Stable
Fair
Normal fishing.
Experiment or use your favorite lures/flies.
Falling
Conditions starting do decline. Approaching front.
Generally fish are more active and feeding.
Speed up your presentation. Work topwater lures and fish shallow. Pack the rain gear just in case
Slightly Lower pressure
Usually overcast or cloudy.
Fish generally move off cover, chase bait shallower and will become more aggressive.
Work the shallows with moderate speed retrieve.
Low
Rainy and Storms
Fish are wary, become less active the longer these conditions exist.
As action subsides try fishing deeper, head for the dock, go rent a movie :)
Let’s face it there are compromises with everything in life fishing is one of them. It’s near impossible to have perfect weather and conditions most of the time and we’re going to have to deal with the conditions Mother Nature deals out if we expect to go fishing.
Armed with a little knowledge we can make the best of most conditions so know your areas, and watch the weather on TV or listen to the weather channel on your VHF. With some preparation and common sense (knowing when to stay in or call it a day) will make your fishing trips more successful and enjoyable.
Notes: I’m no weatherman, nor am I a fisheries biologist. Information stated above is from my personal experience. I did research both in terms of meteorology and biology science throughout the internet and other sources which were deemed both credible and accurate.
Great Article, Thanks for sharing.
My favorite part:
Thats a good read, some of the stuff I already knew but there was some good things in there that should be helpful down the road.
We always planned a camping trip around a full moon, one of the best times I had fishing was when a cold front was just arriving and actually felt the cold air, I've seen minnows, shiners and roaches go crazy during a full moon, they were in huge bait tubs. Anyone hear of Rick Taylor, he has information on lunar times to go fishing.
Check out www.primetimes2.com, I bought one of the package deals a couple years ago, found it pretty interesting.
