1993 Sea Nymph 16 ft vee
water bouy
4
Post by water bouy »
Some pics of the kind of boat I was looking for last year, a '93 Sea Nymph 1672T with a '93 Johnson 30 hp. It's a little wider and sturdier than the '89 Lowe Jumbo V. It looks a lot like a Lund SSV except no aisle in the middle yet. I didn't need it but the price was too reasonable to pass up. The catalogue says it's rated for a 45 hp but I don't remember seeing a motor between 40 and 50.
16 ft Sea Nymph w/30 Johnson
14 ft Monark w/25 Merc XD sold
1994 Lowe 1605 w/50 Evinrude sold
14 ft Lone Star w/15hp Evinrude sold
akboats
2
Post by akboats »
Nice boat cant wait to see everything you have planned.
water bouy
4
Thanks, ak. It'll get a composite floor, casting deck, an aisle in the middle and maybe some storage along the sides.
RStewart
Post by RStewart »
Nice boat. Something like that will be my next build. Can't wait to see what you do with it.
14ft Richline semi v
Sinner by birth...Saved by the Grace of GOD!!!
water bouy
4
Thanks, RS. I'm open to suggestions. All I know for sure is it'll have this 160 lb tiller bad boy on it.
ncfishin
Post by ncfishin »
You da man.
Wish I could buy em and flip em like you.
I know you're going to do it right. Congrats
water bouy
4
Thanks, nc. It came from a place in Conover. The guy there has dozens of boats and no where to put them all. I was actually looking for a 30 hp motor on craigslist when I saw it for not much more than the motor would cost. The thing I'm not sure about is the roller trailer. People don't say many nice things about em.
ncfishin
Post by ncfishin »
You should be able to get some brackets and put some bunks on it. Leave the middle ones for guides. I hear you about the deals tho.
water bouy
4
I hope to get it on the water in a week or so. It's been a long time. Wavering on the middle bench though. The '93 SN catalog lists the hull at .072 thick which is good while a Lund SSV is .063 and I don't see any structural differences. I'd rivet 1/8" angle front and back of the bench before I do any cutting.
water bouy
4
Took it out today for about 30 minutes. It was nice just to be on the water again. It porpoised because all the weight is in the rear for now but otherwise it's awesome. The middle bench really does need to be opened up or I could take a spill. Ditto for a front deck and the rear bench needs to be full length so the seat can move to the middle which could add structural support too. The wood floor is so well fitted it must be from the factory.
DaleH
5
Post by DaleH »
I'd add an SE Sport 200 tail to the OB, if it were mine. Nice rig!
water bouy
4
Always wondered what those tails do. More than likely it'll be get the 40 Mariner before long. The 30 felt a little under powered. The compression is 125 psi but it felt like the throttle wouldn't open all the way up.
ncfishin
Post by ncfishin »
Did you get it out on the water yet? I saw the Lowe boat on Craigslist. Have you had any bites yet? That's a lot of time and work you did on it, I hope you get what you need out of it. I guess you're going to use that Mariner on the new boat. What's up with the extra trailer?
water bouy
4
Thanks nc. I had one nibble and a couple of scammers wanting google numbers which is their new way of getting into email addresses. I wanted a nicer trailer so I wound up with an extra one I have no use for other than a saw horse for the acm panels. Which I bought 3 of today. This time I need to keep the sea nymph usable while it gets upgraded. I only got the Lowe on the water one time since I bought it. If you ever make to town stop on by.
water bouy
4
Set the hook on a piece of silver grey vinyl from Cabela's to motivate me. This heat takes the fun out of summer. Already have 1/8" angle and acm panels ready to go. The layout will be pretty much the same as the last project.
Took up some of the wood floor and cleaned it out but water doesn't drain under the ribs. Can't even get a small wire underneath.
