Spade Bit for Cutting Hole?
fish4thriLLs
Post by fish4thriLLs »
I'm considering using a 1" spade drill bit(made to use on wood) to cut out the hole in the side of my Lowe Big Jon for my bilge pump discharge. I've read that any tool used to drill/cut wood can lots of times be used on aluminum as well.
Anyone ever tried this? Do you think it would work okay?
Thanks everyone for your replies.
1980 Lowe Big Jon 1648
1980 Mercury 25 HP OB w/tiller steering
Bow Mounted Minn Kota Endura 36 Troll M.
Top Speed: 27+ mph
Post by Captain Ahab »
I have and it does not work well - it will tear and catch in the metal
You should use a hole saw - or, if you are like me and work fast and sloppy:
1. trace in marker the spot where you want to put the hole
2, Use a 1/4 drill bit, drill on the inside of the line as many times and you can (use a cross pattern to avoid bending the metal);
3. Using a round file, - connect the dots until you get your hole
If you have a nice sharp drill bit it goes really fast with minimal filing
BOB350RX
Post by BOB350RX »
Captain Ahab wrote:I have and it does not work well - it will tear and catch in the metal
this has to be a pa/dutch/hillbilly thing...lol but it does work, a dremel with a nice sharp carbide burr in it works well also :D just yankin yer chain ahab :D
THIS THING USED TO FLOAT
https://www.tinboats.net/forum/viewtopic ... 21&t=20263, my 82 mirro build
https://www.powerstream.com/wire_size.htm voltage drop, and wire size charts, pretty useful stuff!! not just for 12v either
GTS225
Post by GTS225 »
I do believe that "uni-bits" are made out to 1" .
Roger
bobberboy
Post by bobberboy »
The spade bit will make a hash out of the project. Once the pilot goes through the metal there's nothing to keep the bit centered, the bit begins to wobble and the hole will be a mess. The best is to use a hole saw - they come in sizes up to about 4". You can buy sets or individual saws. If you have to use the spade bit, you should clamp a block of wood behind the hole. That way the point of the bit will remain centered in the wood block as the spade cuts the hole.
If you use the dremel tool wear eye protection
Post by fender66 »
+1. This is the way I've done this successfully. You still have to go very slow and keep the bit straight. A hole saw still will be easier though (I believe).
We want before and after pics too!
gouran01
Post by gouran01 »
you can get the stepped drill bits at the napa etc for bout 7 bucks. the one I have goes to 1 1/8 ". I bought it for nearly the same purpose but have used it very often since. good bang for the buck.
nomowork
Post by nomowork »
I used a jig saw to cut out the holes for navigation lights.
HAPPILY UNEMPLOYED
Derek
Post by Derek »
stepped bit or hole saw are the correct tool for the job
BOB350RX
Post by BOB350RX »
Image[/quote]
OUCH!!!!! tell me that not a personal pic????
LOWEBIGJON
Post by LOWEBIGJON »
I have mine run out the back through the hole already in there with 3/4 inch tubing....I would not cut any holes, if I had too I would just use a hook type pipe or tube to go over the back or side..
LOWE 1852
Yamaha 25 HP ELH 2 stroke
wihil
Post by wihil »
I'd use a knock out, but they're a bit more expensive than a uni-bit.
C
Keepin' the wet side down.
1955 AeroCraft P / 15Hp Johnson
Ranchero50
Post by Ranchero50 »
Unitbit with a 1/4" pilot hole. Open it up to size, then hit it from the back side to debur the inside. A little squirt of WD40 works wonders for aluminum cutting too.
Jamie
devilmutt
Post by devilmutt »
I used a hole saw for the same purpose, worked great.
USMC 88-92
Semper Fi!
My Starcraft Seafarer build https://www.tinboats.net/forum/viewtopic ... 21&t=13674
