crankbait09
Hello all.
I am sure this has been answered a million times over, so if you can post a link to the location I can find the conversation, I would appreciate it.
BUT.............I have a 14ft aluminum jon boat. It is currently a greenish color. I am in the process of fixing some of the flaws and there are some areas that will be sanded down to bare aluminum. 90% of the boat will remain as is. Now, once I finish any sanding I need to do, I will rough up the current paint and apply primer. I will end up painting the boat gray after all said and done.
I read online that I can use Self etching primer as well as another primer called zinc chromate.
Since my boat is already painted and a few cosmetic items need to be fixed, can I use a self etching primer or that other primer to seal it and prep it for the gray paint?
anyone have any different suggestions?
