low hp on a heavy v bottom
bean210
Post by bean210 »
I have a 2003 tracker v14 superguide with a 25hp. I only fish the lake that I live on, mostly because all of the surrounding lakes have a 10hp limit.. my lake has unlimited hp, so there are usually 10-12 jetski's flying around and half a dozen people skiing during the day. I usually go out at dusk, while the whole lake is no wake. i rarely use the 25hp. i put in 3 gals each year, and usually have enough left over to run my chainsaw in the fall :shock:
it is a console boat and needs recarpeted. I was never happy with the layout, as I troll mostly. I am wanting to convert it to a tiller steer, which is simple in the boat, because it looks like the console and other pieces that go along with it, were added to a tiller boat.
since I mostly troll, I thought a 6hp tohatsu would be a good choice. I want an engine with a built in tank, and the 6hp is the largest that I have seen
the boat is heavy, .100 aluminum and a lot of 3/4" plywood decking. id say it weighs 6-700lbs.
sorry,a little long winded. my question is, does anyone else have a large deep v with a small outboard? if so, do you have any tips on prop pitch, etc?
I really like the stability of the boat. it is 74" wide and easy to walk around in (even better, once i remove the console)
DaleH
5
Post by DaleH »
Go to website for Turning Point propellers, https://www.turningpoint.com and they have a whizard calculator for picking the right pitched prop based on your boat (or similar model), the exact motor, and load it carries.
Good choice on the motor! Them or Nissans are my favorite small OBs. Should make that a sweet rig for your use. Save the console for when you ever sell the hull.
bean210
Post by bean210 »
thanks dale, I'll check it out :D
kofkorn
Post by kofkorn »
IMHO, if your local lakes are all 10hp limits, I'd go for a 9.9. That's a 60% increase in hp over the 6 and you will certainly notice the difference when moving on larger lakes.
The built-in tanks are nice, but if you move to a larger lake you're going to need an additional portable tank any way.
Good luck!
bean210
Post by bean210 »
I have considered the 9.8 tohatsu. and the 8hp too. both good choices.
the 6 is about 27lbs lighter. i am trying to shave off as much weight as possible, because my grandson is a few months away from getting his drivers license , and has been claiming my truck since he was 12. if I go anywhere else, I'll have to tow it with our 4cyl car. I want to keep the total package under 1000 lbs.
i'll knock off 175-200 lbs with the engine swap, removing cranking battery, getting rid of the gas tank and console and controls.
actually, if it wasn't for the lack of reverse, I would even look at the 3.5hp tohatsu. I have been using my electric trolling motor 98% of the time. :D
rscottp
6
Post by rscottp »
+1 on the 9.9hp! You may even be able to get up on plane.
bean210
Post by bean210 »
I don't think it will plane. my friend has the same boat in a 16' version and had a 9.9 for the local lakes. it just plowed the water. he had a mechanic switch the intake manifold, carb etc, to convert it to a 15, and while it improved greatly, he still wasn't happy with it.
bean210
Post by bean210 »
this is the 2 versions of the boat that i have.the tiller version is what I would prefer. it looks like a simple process to remove the console, etc
oddly, the pic of the console boat is a left hand drive. must be for the UK :LOL2:
Zum
Post by Zum »
Years ago, I used a 3hp lightwin, on a homemade 12' boat. We would troll all day for trout, sometimes 4 of us in the boat. Certainly wouldn't plane but trolled great all day.
bean210
Post by bean210 »
we took out the boat today. fished for a few minutes and then rode around in the boat for a few minutes. the water was 49*. it topped out at 22mph.
just out of curiosity, we decided to not look at the gps and find a nice comfortable slow speed that we would be happy with. it was 5mph! i'm really getting old 8-[
rscottp
6
Post by rscottp »
Glad to hear you got out on the water, I am jealous! I know you probably don't care but 22mph seems slow for a 25hp on a 14' vhull. Maybe the prop is miss matched?
bean210
Post by bean210 »
I thought about experimenting with the prop when I first got the boat, but honestly, I never ran the outboard enough to motivate me to do it.
it was nice out there. the sun was out, but it was still chilly on the water when moving
there were half a dozen bass boats running 60+ mph :shock:
still to early for jetski's =D>
rscottp
6
Post by rscottp »
I always thought there should be a "season" on jet skis.
TNtroller
Post by TNtroller »
I vote for the 9.9 for a several reasons. You can get a 3 gal tank and the 9.9 will run a long time on 3 gal of gas. You have a bit of extra power if the need ever arose, bad weather, or whatever may happen. Don't know the trolling speed(s) you need for your fishing, but you may have to run the 6 above idle speed and it will be noisy if you convert to a tiller. You don't have to remove the console to run a tiller, but the weight savings and more room will be a benefit. If the 9.9 is too much power for your trolling, you could put a trolling plate on it to slow it down, or use a drift sock.
I was in a glass flats boat last weekend, hull weight of about 450#, 2 guys at 400#, TM battery and TM, very light gear and we put my 5hp 4s on it for giggles (guy does not have a gasser yet) and we were on a small river in Middle TN, at WOT the 5 pushed this weight to 7.2mph per a phone gps app (not very accurate but close), and sitting there with the 5hp at WOT only going 7mph the sound of the motor got old fairly quickly.
Post by Captain Ahab »
Why not add your 6 hp as a kicker motor? Best of both worlds
