It is currently 18 Apr 2019, 17:13
akmccallumco
 Page 1 of 1 [ 6 posts ]
PostPosted: 20 Jul 2016, 16:50
I have a 1969 wards sea king 16ft with a 75 hp Johnson. This thing is a barn find and it had a lot of holes from old rod holders and chrome trim. I'm just making it into a fishing boat and so I wanted to patch all the old holes and I used aluminum brazing to do that. All I did was sanded the surface wiped it with acetone then heated the surface with this butane torch and then used aluminum brazing to patch it and it was easy! And fast! I found these Aluminum brazing rods on amazon and they worked much better then the harbor freight ones.
This method just worked great for me on a budget and so I wanted to share it with you guys! :LOL2: Check It out!!! =D>
This was the brazing rods I used!
https://www.amazon.com/Hot-Max-24008-36 ... B005TGMNCS
This Was the butane torch I used!
https://www.amazon.com/Zenware®-Refillable-Professional-Culinary-Soldering/dp/B01F7PQT16/ref=as_sl_pc_qf_sp_asin_til?tag=smar0ee-20&linkCode=w00&linkId=bcc6bfa38b8b73e0d3d9609e279ac0b2&creativeASIN=B01F7PQT16
You might have to post the link into your window but check it out! It works great!
:D
Thanks for checking it out and let me know what you think!
PostPosted: 20 Jul 2016, 17:41
This is also a great butane torch to check out it works great! and is cheaper then most options. :o
http://amzn.to/2avlvU4
PostPosted: 21 Jul 2016, 11:56
so, you want FAST AND CHEAP patching material ????
Aluminum DUCT TAPE !!!!!!!!!!
Two layers over the offending hole on the outside of the hull.....
sticks CRAZY STUPID tight !!!!
100% waterproof - clean area well with alcohol - apply tape - go boating.
http://www.tinboats.net/how-to-build-a-transom/
http://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = http://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = http://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
PostPosted: 21 Jul 2016, 12:01
Can you post some pictures of the holes before and after?
PostPosted: 22 Jul 2016, 13:12
I am always looking for newer & better ways to do things. However, the reviews on
Amazon are not as encouraging???? richg99
https://smile.amazon.com/Hot-Max-24008- ... smar0ee-20
Always told my kids....If.... "Somebody ought to do something" comes up....remember...you are "SOMEBODY" !!
PostPosted: 22 Jul 2016, 21:36
I haven't had much luck either but I recently saw a guy using this method that was really good at it. Makes me want to re-visit that method and see if I can make it work.
Users browsing this forum: enwez, Google Adsense [Bot], Jebber and 67 guests
akmccallumco
