problem with old timers mix
Carlasdaddy3 said:
I applied 1 coat of old timers mix to stained wooden trim 3 days ago and it is still sticky. Will it ever dry completely?
It does take many days to dry.
What mix did you use? My method was to leave the OTF on there for awhile and let it soak up as much as it can and then wipe off the excess. I wouldn't expect it to be sticky. Mine was mostly dry after 8 hours since it was all soaked into the wood.
