old_boat_new_smile
I have drilled out about 8 rivets to be replace with bolts around and on the transome.
The question is do I need to use rubber washers to make sure I get a good water seal, or what should I use?
This is on an aluminum boat.
The bolts I am using are stainless steel.
Thanks,
P
Thanks,
P
