tripwirenh
Alright, I posted som pics already under "boat talk", but here are some more. This is the beginning. I cleaned her out and will be working on patching the holes and building up the transom. Russ010 recommended Evercoat Aluminox Putty, which looks like my best option to repair the holes other than welding.
Also, I have an 18HP Evinrude though the boat max says 15HP. Does anyone think that will be a big problem? I'm reinforcing the transon with 3/4" ply on the inside and a 2"X12" on the outside.
Boat label says max persons: 520 lbs.
Max weight w/persons, gear, and motor: 720 lbs.
Hopefully it'll be good enough for my mod plans. (using mostly 3/4" ply and 2"X2"s)
