Pruitt1222
Motor is a 73 20 horse but carb isn't, I searched the #'s on the carb but no luck. Anybody have a clue what it is? What year and what motor it came off? Wanting to rebuild it and the primer but cant find nothing on it.
Pruitt1222 said:Thanks Cajuncook but after searching through years of johnson 20+25 horse ipl's I have decided it is a complete carb. It does have it's slow speed needle but its not in the same place as on older motors. Here is a ipl of what my carb looks like.
https://www.boats.net/parts/search/BRP/JOHNSON/1992/J25RWENB%201992/CARBURETOR/parts.html As for the port on the intake its a hair larger then the carb hole. I have decided that I will go on and repair/replace all my fuel lines and pump as needed and remove the flywheel and clean and check the points. As for the carb I think I will just try and rebuild it, The local marine store has it in stock for 17 bucks so I wont be to angry if it doesn't work. I'll keep ya posted on how it turns out
