old_school
- Joined
- Jan 18, 2011
- Messages
- 15
- Reaction score
- 0
Hi all! Figured out what was going on with the 75HP Force and now I have to ask a question about my kicker motor. It is a Yamaha, 1990, 4HP in good shape. Only repair I have done on it was last summer - was not showing a strong stream out of the pee hole and it was hot so I took it apart, cleaned out a ton of sand and small shells (from previous owner running into sand bars), replaced a couple gaskets and a water pump and ran real well, strong pee and water just luke warm.
It has F-N-R shifting (small lever on side of hood) - there is a lubricating fitting for the steering swivel shaft and the shifter arm (where it resides under the power head) - I have greased these but the motor shifts really hard - I do not think it is a lower unit problem - I think it is in the linkage
QUESTION - when I took it apart and reassembled the lower unit (to get to the water pump) you have to separate the 2 piece rod/shifter linkage - could I have not put the clamp back in the right position and now it is binding slightly??
Appreciate if anyone has had this problem - I am thinking of opening the side hole and unscrewing the linkage to see if it was under too much tension in the N position
