. . . so, I'm only the second owner of this OB and up until last night have had no issues with it . . . usually crank it at home beforehand but didn't this time . . . get to the dock, and the recoil start won't budge, almost like it was in gear . . . checked the shifter, all is well . . . pulled the cover, turned the flywheel by hand (hard at first) . . . then cranked it up. Today I pulled the plugs (twin cylinder) and shot some oil into the cylinders and took a compression test, 140 lbs and holding on each cylinder.
Now, sometimes I don't disconnect the fuel line and let the float bowl run out of fuel before trailering but the last time I did . . . so I'm wondering if this is a good idea, since low/no fuel means no oil in cylinders during storage . . . or do I have bigger fish to fry? (no pun)
. . . the main reason I ever ran the float bowl dry is because sometimes the float needle would "stick" in the seat during months of storage.
