Flywheel installation 63 18hp johnson
17ft'r
Soon I will be putting back on my flywheel and was wondering :roll: use something with (3) legs centering around the (inner most part of the wheel dia.), like 120 degrees apart for an (even press).
17ft'r
Put flywheel on crankshaft, aligning key with slot in flywheel an torque to 45 ft lbs.
So, with that procedure it secures the flywheel evenly down onto the crank.
Thanks,
17ft'r
