It is currently 19 Apr 2019, 18:18
mud-skipper
 Page 1 of 2 [ 17 posts ]  Go to page 1, 2  Next
PostPosted: 27 Jun 2016, 11:13
i picked up a 75 johnson 9.9 for a good deal ... i gave it some TLC and last it needs the upper rubber bushing mount/seal done .. i cannot find any info on the procedure, i figure you need to drop the lower end and pull the power head .. any info on this is greatly appreciated.
2014 Tracker 1436 w/ evinrude 9.9
2015 Lowe L1648MT w/ mariner 25
1982 Mariner 4hp
PostPosted: 27 Jun 2016, 11:18
sorry wrong thread!!
my build 1976 14ft Meyers V hull
viewtopic.php?f=21&t=40127
PostPosted: 27 Jun 2016, 11:21
I think that is correct. I'm think Leroy's Ramblings has it covered....however, the site has been down for a week or so for whatever reason. I have a 1980 service manual I can check in tonoight too.
Are you planning on replacing it with OEM parts? They are SUPER high. I have a 15hp with the same issue and if memory serves correct they total like almost $200! I think Leroy's Ramblings say how to modify automotive bushings to make them work. An alternative which I have been looking into is buying a used exhaust leg off Ebay for about $30 shipped and use the used shock from it.
http://www.tinboats.net/forum/viewtopic.php?f=21&t=40764
PostPosted: 27 Jun 2016, 11:38
https://www.marineengine.com/newparts/p ... OMC0340178 here are online pricing for the upper mount .... yea i have been trying to get on leroys rambling but its always down when i try.
1982 Mariner 4hp
PostPosted: 27 Jun 2016, 11:39
perchjerker wrote:
Well I could be mistaken, it was about 17 years ago.
I had a 4 stroke 15hp Merc Bigfoot, was told at the time by people in the know that the top was Yam rest was Merc. Maybe it was a 2000 I don't really recall it that makes a difference.
The kicker I have now on my Grady is a 99 9.9 Yam 4 stroke and the powerhead looked exactly the same.
I suppose both could be Tohastu.
Bottom line for me is both were great motors (for me anyway)
sorry but what does this have to do with the thread topic in this thread???
1982 Mariner 4hp
PostPosted: 27 Jun 2016, 12:15
I have made those mounts out of rubber plugs bought at Lowe's for a couple bucks each.
Have done it on a few motors with great success.
Craig
Be Who You Are
And Say What You Feel
Because Those That Mind ....Don't Matter
And Those Who Matter....Don't Mind
PostPosted: 27 Jun 2016, 12:19
Here is the expensive part I was referring to http://www.marineengine.com/newparts/part_details.php?pnum=OMC0436469.
It may not be one that needs replacing though. I never researched it enough to see exactly what all new parts would likely be needed.
PostPosted: 27 Jun 2016, 12:27
ahhh i see ... think i'll just rip it apart and have a look at it ... it's definately in need ...
1982 Mariner 4hp
PostPosted: 27 Jun 2016, 12:40
lol oops that was for a different thread
PostPosted: 27 Jun 2016, 23:29
I made a set using polyurethane sway bar bushings. If you have a drill press and a hand grinder or dremel of some sort it is easy to make them. Grind down the outside hour glass shape. Insert poly in housing. Press the bushing inside the poly to expand to housing and walla...
...And they are a pretty blue as a bonus 8) ..though one can't see them..
2 stroke every time I can
4 stroke only when I have to..I don't like boating with my lawn mower
PostPosted: 28 Jun 2016, 07:34
great idea, sure beats 2 mounts at a bill each .... what where the swaybar bushing for that you used??? i'm gonna try this before i dump about 200 more into this motor.
1982 Mariner 4hp
PostPosted: 28 Jun 2016, 08:34
do you by any chance have a link for the rubber plugs??
1982 Mariner 4hp
PostPosted: 28 Jun 2016, 12:28
They are 1.5 inch rubber plugs
Craig
Be Who You Are
PostPosted: 28 Jun 2016, 15:45
I've tried rubber but for me poly machines easier. I went into a napa and asked for a universal sway bar kit. Bought a set of 6 for 13 dollars.
PostPosted: 28 Jun 2016, 21:36
thanks for the input guys .. i'm gonna pick up a set or two of each and see what i can come up with ... to do all the seals and mounts OEM gonna be about 300 bucks so this is for sure worth a try!
1982 Mariner 4hp
Users browsing this forum: No registered users and 61 guests
FishonFabrications
