samuelh1987 said:Took delivery of a new Suzuki DF9.9B last week. First EFI motor. Took advantage of the Suzuki since it's easy to convert to a 15/20 if I end up with a larger hull down the road.
PATRIOT2 said:samuelh1987 said:Took delivery of a new Suzuki DF9.9B last week. First EFI motor. Took advantage of the Suzuki since it's easy to convert to a 15/20 if I end up with a larger hull down the road.
I'd be interested in knowing when your oil change monitor starts flashing the first time during the break-in period . . . mine started just a few hours after I installed it which tells me the factory must have run it a while to test before shipment.
samuelh1987 said:aftermarket sds kits at 65-70 isnt bad at all. I never thought about that. A decent tiny tach is nearly that much.
Word is you replace the existing restrictor to the 'arrestor' of the 15hp and PRESTO ... you have about a 15hp motor.samuelh1987 said:Its rated for 15hp so we'll see how the 9.9 does before making adjustments.
DaleH said:Word is you replace the existing restrictor to the 'arrestor' of the 15hp and PRESTO ... you have about a 15hp motor.samuelh1987 said:Its rated for 15hp so we'll see how the 9.9 does before making adjustments.
InSaneFisherMan said:DaleH said:Word is you replace the existing restrictor to the 'arrestor' of the 15hp and PRESTO ... you have about a 15hp motor.samuelh1987 said:Its rated for 15hp so we'll see how the 9.9 does before making adjustments.
I went with the 20hp arrestor, some people drill out the 9.9 restrictor or just remove it. I’m pretty sure that will get you close to a 15hp, but you will have rev limiting at 6000rpm.
The 20hp ECU solves the rev limiting and gets you up to the 20hp.
There are also some good videos on YouTube that shows the conversion.
I dunno . . . finally got my real DF20ATS thru the break-in period this week and it tops out at 25mph WOT (not that speed really matters) on the same hull that I ran my old Nissan NS15B carbed 2-stroke at 21 mph. The difference in fuel mileage was incredible and only having to carry less than half the fuel; 6.2 mpg on the 2-stroke vs. 15 mpg on the 4-stroke.
