guyute1500
- Joined
- Jan 1, 2023
- Messages
- Reaction score
- LOCATION
- Coplay, PA
Hi guys, last year I bought a 14' seafarer with this motor and did a lot of fishing with trolling motor and never used the johnson. The boat had been sitting for a few years and I was told the carb had been worked on and it should run. Was planning on having someone go over it but it never happened. It's almost fishing season here in Pa and decided to take a look myself. First thing I noticed, besides the throttle being almost unturnable, was that there was no fuel pump. Ordered a new one, some new lines, and a couple plugs. Lubed up throttle handle and installed new stuff, put her in a 55 gallon drum. She started right up! Unfortunately I didn't get any water out of the pee hole. Blew the hole out,took the hose off and blew through it. Everything seemed good there so I ordered a new pump, had to be done anyway. The old impeller was toast, maybe one fin left. I tried to blow everything out and didn't see plastic anywhere. Installed new pump and still no water. Impeller key didn't stay so redid and tried again still no water. Decided to do the drill test and the water pump is not pumping anything. Could it be as simple as bad water pump? Any ideas?
