BlakeRauch said:Dig it. Looking really good so far.
Thanks Man
huntinfool said:First off, great job on your project. It looks like it is very fishable now.
Question, what are you using for your LED nav lights?
I've added internal LED's to my boat. But I have been looking for a LED nav lights and like the look of those.
huntinfool said:Did you use a webbing agent?;
I spray gel coat all the time and web it like that. Might be my phone but colors look to be a sand and metallic blue. Personally the color doesn't do it for me, but my boat is camo.
But as far as the webbing....nailed it.
jy951 said:Looks great. Can you explain how you attached the wood on the bow that you attach the trolling motor too. Thanks.
I went with a 48 but only because I couldnt get a 42 in the power drive.tsezan said:what was the shaft length of the minn kota you ended up going with? I have basically the same boat. I can not decide if I need a 48" or longer..
Thanks, i wish I would have chose a diff model with thicker more durable construction.Gators5220 said:Looks good man, I have a much older boat that I'm working on a similar layout.
cesargomez1003 said:Nice build, I have a lowe 160fm which is similar to yours and I love mine. Is the powerdrive 24v? Also have you tried the tm yet?Thinking of upgrading my 45lb edge to a powerdrive 55lb just not sure if the 10lb upgrade is worth 600 bucks.
