12' Sears
CLICK FREE
Looks good, are you going to cover the hole at the center bench? I know every lure I own would eventually end up there... LOL
Yeah, I wasn't going to worry about the hole at first but as I was working on the boat every tool I was using seemed to fall through there so now I will close up the hole.
looks awsome Andy!! what did you use under the carpet, and how much weight did you add to the old girl ??
That is really nice =D> Have you had it in the water yet???? I too have a 12 footer similar to yours and I too wanted to deck it untill I put it in the water. :shock: Mine is really tippy as it is!!! I'm worried it may be worse if i raise the floor, although I've seen it done alot here!!! How did yours do????
