socal
hello every one. found this site from iboats and thought i would post here for info on how this is done. i already did some searching but i thought i would post this to see what you think. i just bought this boat thinking it would be a recarpet and seat deal but i started looking at the transom and fell it is toast. i lower the motor and it sags alittle and i can make it bounce if i want, so that cant be good. i'll post pics and you guys can tell me what you think i should do. also the fin on the bottom end of the motor got bent and the tip broke off, can this be repaired?
i figure i have to take the two end caps off then the strip that goes across the top and remove all the bolts and screws off the back, along with the motor. there's a hook on the top of the motor is that where i hook it to pull it off? what would be the best plywood to use and what do you do to it to prepare it before you install it. i see some use epoxy and some use resin.also can you tell me where i do the intro?
https://i613.photobucket.com/albums/tt215/socaldrifter/54a76bb0.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/e43f57be.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/797a28cc.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/0c6bff53.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/5a171342.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/25b7daf5.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/0540c859.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/56a3d8d1.jpg
https://i613.photobucket.com/albums/tt215/socaldrifter/765216d7.jpg
