stevesecotec02 said:2 stroke or 4? I have a 94 should be pretty similar to yours if its a 2 stroke. The hub is biilt into prop I run a solas amita aluminum 3 blade 13pitch. It pushes my 1648 with 2 people and gear at 28mph I could probably get away eith a 14pitch as the 13 is at upper range of recomended rpm but when I throw in more gear or people the 13pitch comes in handy.
stevesecotec02 said:Its hard to say without knowing the rpms but heres my setup. Alumacraft mv 1648 (320 lbs) tolling motor and 2 batteries (135 lbs) 2 people and other gear (600) lbs. So im pushing an estimated 1055 lbs with an aluminum 13pitch and I get 28mph and am at the upper rpm range for the motor. Mercury says to use a 14pitch for the weight im pushing but I occasionally load heavier so I stay with the 13. Hope this helps.
