Lonestarluck
Hey everybody, this site is awesome, I've been creeping around here for a while and now I've finally started my project and want to share it. My brother in law and I traded some plumbing work for this project last year and due to a long list of honey do's and other "priorities" we're just now starting on it.
Here's what we started with:
1975 Mirro Craft 14' Semi V hull (used for a cat house for last 20 years, rotten transom)
1971 Dilly tilt trailer (with two flat tires and sash cord for a winch line)
1964 Johnson Sea Horse 9.5hp outboard. (Excellent condition)
19?? Sears Craftsman trolling motor (unused in original box)
Also got a couple anchors, a set of 6' oars, a perfect condition evinrude gas tank and motor stand
The 9.5hp motor sold on Craigslist for almost enough to cover our entire investment in this boat. A friend had a 1977 Johnson 25hp tiller that we got for $300. Has good compression but needs a little elbow grease in a few spots. The rotten transom was removed right away and there is a mew one in the shop waiting on one more coat of SPAR. Hopefully we'll start the install of aluminum deck framing soon. We'll be using some ideas we've seen on here and some of our own.
Our future plans include front and rear casting decks, an aluminum tube framed center console, upgrade 25hp motor with 35hp carb and intake, mini jack plate and possibly tilt/trim plate, storage and foam under decks. All of our plans will be executed as simply and cheaply as possible while still being done right. We have access to a friend with a TIG machine and JD squared tubing bender that will be helping us with the aluminum fab parts of the project.
HAVING TROUBLE WITH PICTURES BECAUSE OF THE 800 pixel limit.
