Loggerhead Mike
Sorry bud didn't mean to sound like an ***
Loggerhead Mike said:Sorry bud didn't mean to sound like an ***
wasilvers said:Had that happen on my van. Unfortunatley, all the repairs run together but it was about $400 to fix. It sounded like rubbing, but not all the time. Tires didn't wiggle, though, and I couldn't load it up one way or the other.
Hanr3 said:I'm hesitent to believe its a transmission. Shifting issues and leaking fluid are your typical indicators, if you suspect the tranny, pull the tranny dipstick and check the color and smell it. IF it is black or metalic, or has a distinct burnt odor, tehn yea tranny.
IT could still be a wheel bearing or CV shaft, the noise travels through the half shafts into the tranny, thus making it sound like a tranny issue. Remember the screwdriver sound testing trick mentioned earlier? The virbation travels through the tang of the driver intot he handle and into your ear when you place it next to the handle. Same thing could be happening with your bearing, cv, tranny. Noise travels.
Best test for bearings is turns, if the pitch changes it means a bearing. To determine which bearing, jack the van up, and grab the tire at 12 and 6 oclock positions and try to rock it up and down, no grab it at 3 and 9 oclock positions and try to rock it side to side. 1/16" of an inch movement, especially up and down is all it takes for a wheel bearing. I have seen bearings with no movement still bad. Another option, take it to a shop you trust and get a free estimate.
The typical indicator for a cv joint is a busted rubber boot. Look for grease all over and a hole int eh boot.
Now when I was in your situation, I replaced both the CV and the bearing with lifetime replacement units. The easiest way to replace the cv is to pull the bearing. The other option is to disconnect a ball joint and tie rod, then you need to pay for a front end alignment when your done. Cheaper to pull the bearing to pull the cv shaft, might as well replace them both while you have that bearing out. Sure I may be replacing a part that doesnt need it, yet! However if your like me, your van has some mileage and its only a matter of time before the other goes, then your doing the work again.
JamesM56alum said::mrgreen: If it's a ford, a gallon of gas an a match will go along way!! lol ever seen the ford emblem ? they circled the problem from the factory! Ford = Fked over rebuilt dodge, fix or repair daily,found on road dead, Driver returns on foot...
sorry i had to lighten the mood in the thread it was gettin pretty stale in here!
