Two 1/2" sheets to make 8' long and 90" trimmed down to 53" wide, One thickness. wanting to laminate the two sheets together and trim to 53"wide and have glued seam down the middle. Do I power planer the overlapping edge to a 1/4" thickness and 3" wide then glue and screw together. Making a Lap joint with plywood. Glue or Resin as adhesive to hold sheets together. 1992 Smokercraft Alaskan 13' Thanks, Randy
