mtydg
I would like some feed back on the placement of guide bunks or side bunks. How much space is normally allowable or needed between the width of the boat and the bunks?
Thanks for the feed back. I am setting them at the 1.5 inch mark and will check them after a few loadings.[url=https://www.tinboats.net/forum/viewtopic.php?p=326883#p326883 said:chrispy186 » Today, 17:29[/url]"]Mine are about 1/2" on each side too. Gives the boat a little wiggle room, but not too much. Also make sure when you install the side bunks that the boat is exactly where you want it on the trailer. Also, after you hit them a few times wih the boat, be sure and check to make sure they are still tight.
