interior paint suggestions
rewinder
NH
I bought this boat last spring
I want to repaint the interior of this mid 70's princecraft. As you can see it's faded out and not flakey in any way. I put new seats on last summer, and raised the transom for a long shaft motor.
I don't want a piece of art, just a good functional paint job that's not to involved.
I use it a lot in salt, and rinse it out well on every use.
When I re-furbed it last spring, I replaced the foam under the seats, and there was only slight pitting on the interior floor under the 2 rear side seats. I scrubbed it with a 3M pad and put in foam and used it all summer. Should I do anything else to that slightly pitted area this season, in conjunction with the interior paint job?
Also the outside blue is faded, and will buff out nicely with a rubbing compound and wax (I'll do that this spring) But the bottom below the spray rail need to be cleaned up to remove waterline stain-- any suggestions there?
thanks in advance for suggestions. Grandsons and I had a blast in that thing last summer
Although I use my tin only in fresh water, I painted my interior with Rustoleum oxide primer and regular Rustoleum paint. I figured that the inside won't get as wet as the outside, I hope! I did use marine grade primer and paint on the outside though. $$$$$$$$$$$$$$$$$$
