Monark Mod
linesider
Raleigh, NC
Another one of those that has been looking at this site for a long time and finally decided to show what I'm doing with mine. I've been looking at everyones mod's almost everyday and I've gotten a lot of great ideas. I inhereted a monark from my father-in-law. It's 12' long and the bottom is 40" at the widest part. I've spent the last 1 1/2 years working on it when I have free time. I'll post some before pics now and add some of what I've done soon. I think I'm getting close to working on the wiring but as I started getting into it I have more questions than I ever thought I would.
I posted the wrong picture to show the previous wiring. The one pic of the switch panel shows the circuit breaker for the trolling motor.
Ok, here are some more pics of what I did after I gutted all the existing wood. I also disconnected all the lights and other electronics. The bilge pump was never hardwired, it just had alligator clips. I also took off the switch panel and tossed it. I wish I hadn’t because now I think I could have used it later. The TM was wired to a terminal bloc (I think that’s the correct terminology) and the alligator clips were attached when wanting to use it. I blew many fuses doing this because the clips were so close together when attached to the term. bloc.
I didn’t mention it in my first post that I have fished off of this boat for a few years before I brought it back home to modify it. It’s a very sturdy boat and no leaks that I’ve seen over the years.
The new flooring is all ¾” plywood. I’m using a 2 x 4 piece on the back rib between the bow and the middle seat and a ¾” x 1” piece of wood on the front rib in the same area. This allows for a level flooring. A picture attached shows this. Chime in if you think I’ll need more bracing. It seems very sturdy to me when testing it. I decided to screw the flooring between the middle and back seat directly to the ribs instead of additional bracing. I didn’t want to raise the floor any in the back. I’ve treated all the wood with water sealant as well.
Of course I did it again. The picture below shows that the 3/4" x 1" wooden brace spans the entire width of the boat. The earlier photo showed a piece that was too short. I'll get this right sooner or later.
Ok, nevermind. This is the same short board. I need to look at my photos better before posting. Apparently I don't have a pic of the correct board.
