Webygail13
- Joined
- May 9, 2015
- Messages
- Reaction score
- 0
I have a 2003 Mercury 90/65 jet. I bought it used from a dealer and have been pretty happy with the motor. I got it last summer and the first time I went to the river with it. I drained the battery trying to get it to start. Went back the next day and finally, it started up. After starting it, it ran like a top. If I cut it off, it fires right back up every time. All last summer through the fall, when I would go fishing, it would take a good 3-5 minutes of cranking on it to get it to start. Fast-forward to this spring, I take the boat out, drain the battery trying to get it to start. Went back the next day, still nothing, so I hit it with a shot of starter fluid, fires right up, runs like a top. Cranks up every time after that. I got home, cleaned the carbs, replaced the fuel pump and the enricher valve. I figured I would just replace all of the stuff that I knew effected getting fuel to the carbs. Went back out, same junk. Had to spray starter fluid to get it started. Now though, it's not cranking up as quickly after I've been running it. My bulb stays tight all day, and when I'm trying to start it I pump the bulb until its tight and it stays that way. I've replaced the plugs as well. I feel like I have to be missing something. I have fresh fuel in it and it still hard to start. I can't understand why it runs so good and cranks so good after running, but won't crank when cold. Any ideas would be super helpful. I've taken my kids to the boat ramp too many times to have to turn around and come home because the boat won't start!! Thanks.
