My trolling motor went overboard.
Hotaluminium
I just purchased a new trolling motor (transit mounted style) and mounted on the bow. I clamped it directly to the aluminum. Before I took the boat out I checked the two screwed and it was right. Out on the water I hit a wave, and the trolling motor went right off and into the water never to be seen again. How can I prevent this from happening again?!?!?
I’m really surprised you haven’t gotten any feedback on this yet. First off, man that sucks and I feel for ya! To make sure this doesn’t happen again you need to make a very over built L shaped wood block and it needs to be through bolted to the boat with stainless bolts and washers. I will post of pic of what I’m doing on my boat so you can see what I’m talking about.
Here is what I’m doing on my boat. Again, this mount will get through bolted to deck and I’ll use something a little bigger than 1/4 size bolts with some big washers.
I did something similar except i used a piece of AL angle and bolted and glued the wood to the angle then bolted the angle to the boat.
Ok, I was going to post a picture but it looks like we've changed the way this thing works again. I'll have to figure it out again.
Sounds like that would work for sure.
Guess I should have shown how I attached the two pieces of wood. The bottom piece is a 2x6 and the top is a 4x4 post that I ripped on the table saw. I then used 4 3” exterior grade lag screws to tie them together. These lag screws are designed to hold a lot of weight and over the years I’ve successfully used them to tie garage shelving to studs and interior walls to rafters.
I would either fabricate a bracket like shown above, or better yet, get a bow mounted trolling motor and mount it properly which may require fabrication of a front deck/mount. Clamping a trolling motor to the aluminum is probably not the greatest idea unless it is on the transom that is flat and usually has a lip to keep the clamps from slipping up. The gunwales are usually an odd shape and won't hold the clamps well.
That LIP is the key! You will never lose a trolling motor.
I’ll take a better pic this eve.
