Sign Ply for flooring?
Yes, I believe it will be sturdy enough, but that is because I know how I frame things. You will still need to seal all the edges of that product, which seems like a lot less work then the whole surface. I would also be curious to see what it costs though.
huntinfool said:
I contacted this company about their alumilite a few months ago....very scary on the pricing.
do you remember the $? Ballpark?
was thinking of contacting a local sign shop to see if they had something like this
https://www.alumapanel.com/view_product.cfm?step=1&lines_ID=290&name=Nu%2DAlum%20White%20Aluminum%201%20Side%20With%20Poly%20Backer
Size Gauge: 1-5 6-19 20+
48"x96" 1/2" $91.43 $88.89 $85.33
48"x120" 1/2" $114.29 $111.11 $106.66
Available Color(s): White
Pre-painted .015 aluminum laminated to one side exterior grade plywood. Poly backer is laminated to the other. Easily fabricated with normal woodworking tools. Factory masked faces.
We use a lot of this stuff. Great Product, lightweight, durable and strong.
https://www.alumapanel.com/view_product.cfm?step=1&lines_ID=618&name=Scooter%20Board
Size Gauge: 1-19 20-49 50+
6" x 24" 3/16" $1.39 $1.30 $1.27
18" x 24" 3/16" $4.16 $3.91 $3.79
24" x 36" 3/16" $8.03 $7.55 $7.32
48" x 96" 3/16" $44.36 $41.67 $40.44
1/2" $60.53 $58.75 $57.07
Lightweight, moisture resistant hardboard that is ready to apply vinyl, screen print, digital flat bed print or laser engrave. Features a durable,brilliant, stain resitant white finish.
Great for real estate signs as it easily slips into our universal sign frame.
For those prices why would someone bother??? After the time invested in sealing up all edges and paying that insane price??? Might just as well buy pure aluminum. :shock:
I used some a few years back, I usually find a few pieces every spring from highway signs that get broken off by snowplows. Anyway, seemed to hold up pretty well.
Or at least, just regular plywood. The two layers of .015 aluminum aren't gaining you much of anything over regular ply, yet will make it harder to install carpet. The value of the sign ply is if you were painting it - the aluminum face will hold the paint better than the wood does, but I fail to see any advantages beyond.
Thanks for all the feedback and info. The price is pretty steep and not a lot of gain over standard ply seems to be the theme. have a project jon sitting in the garage and with a newborn in the house have had plenty of design thinking time but not much doing time yet. Seemed like a good idea/product when I ran across it. Have seen plenty of wood framing and alum just wondering what other options there are out there. If Trex decking was not so heavy and expensive I would love to have a deck that looked, well like a deck.
