TM depth collar broke?
sbritt23
Shallotte, North Carolina
So i was messing with my trolling motor and i went to go adjust the depth collar and the dog bolt that the knob attaches too is seized up and the knob came off. Anyone know a simple way to get this old collar off and maybe make a homemade one i gotta use it this weekend and dont have time to order a replacement collar for it
get a collar from home depot etc... you have to take the control box off to slide the collar off and put new one on...or in a pinch you could just use vise grips for a collar till you get a new one
sbritt23 said:
Whats this collar you speak of at home depot im about to head there in a few anyways
its not called a collar...its a connecter for pipe...looks almost like the depth collar on ur TM but its made of metal. somebody there will be able to help you find it.
Can you look it up on either lowes or home depot website and post the link. So i can see what your talking about i went today and couldnt find nothimg i coul d use.
You say the bolt is seized up. Does that mean the collar is stuck in the position you normally have it when you troll? If so couldn't you just leave it there until the part comes? As far as I know, mine could be seized up. I haven't tried to adjust it in a couple years.
If you really need to adjust it or need a new temporary way to lock in place, maybe you could drill the bolt out and put a new bolt w/ nut and washers in there until you order your new collar. I assume this is the part we are talking about https://www.trollingmotorparts.com/(S(ic5hms55iqxk0aabjmbbwxmx))/default.aspx/act/Catalog.aspx/catalogid/9230/Subcategory/Mounting+Brackets/category/Minnkota/browse/MenuGroup/Home/desc/Minn+Kota+Depth+Collar-KNOB+SOLD+SEPERATE.htm?AspxAutoDetectCookieSupport=1
If that's not possible, maybe you could cut the collar off and use a hose clamp with a peice of rubber hose approx. the same dia as your shaft. If you cut a slit in the hose, you could slide it on without even removing the control box.
Or even better, I just found this https://www.homedepot.com/webapp/catalog/servlet/Search?storeId=10051&langId=-1&catalogId=10053&keyword=double+bolt%20hose%20clamp&Ns=None&Ntpr=1&Ntpc=1&selectedCatgry=Search+All
Not sure this helps, but this is how I rigged mine.
EDIT: I just realized you were talking about the part that rests on the bracket pictured. Sorry. :oops:
im trying to find it now
Mine just stripped the other day. Could you explain what you did here? Looks like you're holding a nut in place with a hose clamp.
Thanks
Thanks
Exactly!!! If they knew how to engineer at MK, I wouldn't need to perfect my equipment. :mrgreen:
Drill a hole in the clamp large enough to insert the tensioner bolt through. I drilled a hole in the collar smaller than the nut, and forced the nut in place with a C clamp and heat gun.
