Hi - I just became proud owner of a 1971 montomery wards sea king 14' semi-V (it's not flat anyway). It had the serial plate, and from that I was able to date it 1971 and the manufacturer code says it was made by smokercraft.
Anyway, got this baby in rough shape for $100! The hull is in pretty dang good shape - no major dings, and held water very well on a little maiden voyage using my lightwin 3hp. The transom is badly rotted, though, and the seats need to be replaced.
My most immediate need is the transom work so I can go fishing! My question is about transom thickness. This thing had obviously had transom work done by a previous owner. I've disassembled what was there, which was an approx 4' x 3/4" piece that goes across the to length of the inside stern, and then a trapezoid piece about 12" on the top, 4" on the bottom and 12" on the sides. Thickness of that outer piece measured 1", but I'm thinking it was originally 3/4". Outer piece is plywood, while the inside piece was solid. I'm attaching a couple of photos post-demoed - I'm not where the boat is, so that's all I've got for now.
I'm wondering if this previous owners work was an accurate replacement. Do those thicknesses seem reasonable? Otherwise, the dimensions seem to match what look to be original paint lines of the boat. I bought some 3/4 plywood, resin and some spar urethane after reading up here. Just wondering if I should beef up the thickness by laminating.
I have a 15hp evinrude 2 stroke I'd like to use on this eventually, so I want to make sure I'm rebuilding the transom up to original spec, since I think that 15hp would probably about be the limit.
Any insights are most appreciated. I was so happy to find a boat for $100. We just got a place on a little lake in WI that this should be just a perfect size for. And the price was spot on for being cash starved after getting the cabin!
