Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
Wayne Air Compressor?
Talk about anything that floats your boat (no pun intended). This is general talk about anything not related to boating/fishing.
lckstckn2smknbrls
Post by lckstckn2smknbrls »
A neighbor was getting rid of a very old Wayne air compressor. It's model number is F22HP from the mid 50's or older. I'm not finding too much info on Wayne compressors but they made a high quality compressor used in service stations and air brake repair shops. The one I have is kind of odd it has a small single cylinder single stage pump with a very big heavy 1/2hp 1725rpm motor and a large 40 gallon tank. All of the pictures of Wayne compressors I have seen are stationary models and this one is a portable model with steel wheels. It does run but the pump is leaking oil at the crankshaft seal and leaking oil into the tank. My plan is to have the tank hydrostatic tested and use it as a receiver tank. Then I'll clean up and paint the pump, motor and mount them on finished oak base for display.
Post by richg99 »
Should be nice, though I don't have the extra space for such a large display. It is a shame that you cannot repair the oil leak easily.
lckstckn2smknbrls
richg99 wrote:Should be nice, though I don't have the extra space for such a large display. It is a shame that you cannot repair the oil leak easily.
I don't have the space to keep it when it is fully assembled. The tank if its safe to use is going under some shelving in my garage and the pump and motor will be on display in my dads wood working shop with his antique and vintage tools.
