Electric trolling motor speed control
Shesabugger
Has any one made or know where to purchase a variable speed control switch for a Minn Kotta Endurance motor?
I would like to have control of the speed setting from a remote switch not located on the tiller handle.
Does this exist?
Thanks !
If you are wanting to have the control head away from the actual TM motor, just google trolling motor on a yak/kayak or cutting down a trolling motor shaft for a yak. You tube has some videos as well, take your time as once you cut the shaft you have voided any warranty you may have remaining.
Does this exist?
Thanks !
This:
[youtube]7Esb8oY-Juk[/youtube]
Ok. I have some options,thanks
So I could take the circuit board from under the plastic TM housing and then re mount it in another smaller plastic box , such as a ammo box, then attach a new knob to control the circuit board ?
Is this making sense?
Or I could get the unit from China....which would give me PWM circuit control.
