Tapatalk has been disabled due to being incompatible with the current version of the forum software. Will be re-enabled once it's fixed.
prop r&r
hipster dufus
prop r&r
Post by hipster dufus »
one too many dings in my tohatsu 30 hp efi 4 stroke s prop. just ordered new oem prop. do i need anything else to replace it? other then marine grease? thanks
Snowshoe
6
prop r&r
Post by Snowshoe »
Cotter pin.
lckstckn2smknbrls
prop r&r
Post by lckstckn2smknbrls »
Have you check the motors rpms to see if you should move up or down in pitch?
