2-Stroke Refresher
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
Hi everyone, I’ve been away from the forums for a while (new job + new baby). I hope all are well.
I’m using my 2 weeks of paternity leave (during which my main responsibility seems to be to keep our 4 year old from driving my wife nuts) to FINALLY get my tinny going for the summer, and I cannot get my 3.5 Johnson started for the life of me.
It has fresh gas and will run on starting fluid, so It’s got air and spark. This tells me it’s probably a clogged jet, but I’m not sure how since I ran the carb dry before putting the boat up for the winter.
Could someone give me a suggestion or two on how to get this thing running?
Thanks!
John
CedarRiverScooter
5
2-Stroke Refresher
Post by CedarRiverScooter »
I have a 4hp Evinrude & had same starting problem. I put in a new float, needle & seat, also replaced the packing around the mix needles. Cleaned it well.
The float was original cork one!
Not a hard job.
It starts 1 pull now, so well worth the effort.
The kit was about $20, get an OMC one.
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
CedarRiverScooter wrote:I have a 4hp Evinrude & had same starting problem. I put in a new float, needle & seat, also replaced the packing around the mix needles. Cleaned it well.
Not a hard job.
Carburetors are my kryptonite. Sigh. I guess I have to get over my phobia at some point.
Thanks!
LDUBS
3
2-Stroke Refresher
Post by LDUBS »
Congrats on the new baby and the new job!! =D>
Have Rod - Will Fish
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
LDUBS wrote:Congrats on the new baby and the new job!! =D>
Thanks! My daughter, who is 4, offered to teach him to fish Image
Life is pretty good sometimes even when a #%^*ing carburetor is clogged. Again.
CedarRiverScooter
5
2-Stroke Refresher
The worst part of the job was removing the cheesy wire hose clamps.
Look for a utube how-to. Lay out the parts you remove in order on a bench.
Set float height by turning upside down & look that it is parallel with carb body.
Bend tab with pinch nose pliers to change it (I had to), but it doesn't take much.
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
CedarRiverScooter wrote:The worst part of the job was removing the cheesy wire hose clamps.
Thanks!
jethro
6
2-Stroke Refresher
Post by jethro »
SeaFaring wrote: This tells me it’s probably a clogged jet, but I’m not sure how since I ran the carb dry before putting the boat up for the winter.
Thanks!
John
My experience with small motors is that running them dry is not good. The reason is that the jet ports are so small in these carbs that they can varnish almost instantly when you run them dry. I would suggest not doing that in the future and keeping the jets in a bath of liquid gas instead, but that is just my experience. Also air is a killer. Oxidation and corrosion is kept at bay when gas is present. I always just store my small equipment full with treated gas rather than running them dry.
I would take the carb apart and soak the jets concentrating especially the float valve jet.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
Thanks!
John
That makes sense to me - thanks!
I treat all of my gas since I don’t have ethanol free available nearby. I will definitely give that a try.
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
So, I finally just pulled the carb. The needle had fallen out of its seat, so the gas was basically in free flow regardless of the float height.
I fixed that, and it will run with the choke on, but not otherwise. Looks like I need to rebuild the damn thing.
I’m getting a bit more confident with carbs, but wow, do I ever hate the infernal things.
I picked up a 2001 15 hp Johnson for (very) small money, but it also needs carb work and a new recoil spring. I guess I’ll do that one first since the rebuild kits are easier to come by.
Does anyone know why the Johnson kill switch assemblies are so effing expensive? It’s not like a kill switch is a piece of sophisticated equipment. $100-$150 seems nuts. My 15 hp motor has one, but it looks a little suspect. I know there are aftermarket universal ones for cheap, but it’s the mounting bracket for the switch that I really need.
John
CedarRiverScooter
5
2-Stroke Refresher
My guess would be lawyers.
Regarding your 3.5 carb, you could try taking the low & hi spp\eed needles out & squirting carb cleaner in, maybe rinse & repeat a few times.
There wasn't any other passages on mine. I cleaned up the needles with a scotchbrite pad, go easy on them!
SeaFaring
2
2-Stroke Refresher
Post by SeaFaring »
Thanks for the tip - it is a really simple part.
Re: lawyers, as much as I hate to say it (being a lawyer myself, although not a trial lawyer) you’re probably right. Sigh.
turbotodd
2-Stroke Refresher
Post by turbotodd »
I get the same story day in and day out at work. "I run it out of fuel every time"...yet the carb(s) are still dirty/plugged/restricted with staled fuel. How? When the engine dies, we assume the carburetor's dry. It's not. The jet doesn't go all the way to the bottom, so there's still fuel leftover sitting in the bottom of the bowl, it stales and then causes issues. Do not know about OMC, but a lot of Brunswick and also a lot of the Japanese outboards that I've worked with have a drain screw in the bottom of the bowl, which drains what's left. Same for the VST on the fuel injected outboards. Good practice to drain it if it ain't gonna be used for a while. The other option...which I had success with on my old 25, leave the fuel line hooked up all the time. As fuel evaporates from the bowl through the vent, it's replenished with fuel from the tank/line(s). Never had a single carburetor issue doing it that way, and yes it did sit for a few months at a time during the winters.
Pappy
2-Stroke Refresher
Post by Pappy »
Only problem I see with the fuel line remaining connected to the engine is if the boat/engine is stored inside a garage or enclosure. If the needle/seat assembly got a piece of debris stuck between it then the system will free-flow as Todd explained. In an enclosed area this could spell disaster. Not sounding an alarm.....common sense prevails !
