I agree that it is likely underpowered, but not terribly so. A 35 would likely be a better match.gpm wrote: ↑25 Nov 2021, 14:44 I have found a 1998 crestliner 1650 fish hawk with a 20 hp 4 stroke Merc with open passage one end to the other. If I elect not to modify my u14 valco as we have been talking about and purchase the crestliner do any of you have an opinion about the 20 hp merc being grossly underpowered for the boat? Owner indicates 20 mph with 2 adults and 2 young grdkids.
jerry
structural integrity compromised
- 4
- Site Sponsor
- 3
I have a 1751 - 1 foot longer than the boat you're considering buying. Mine is flat bottom so it gets up on plane quickly and doesn't plow through the water the way a fish hawk will. I have a 40hp motor and can get to 29mph. I've tried to break 30mph several times and can't get there.
He might have gotten 20mph out of his 20hp motor but that seems like a stretch to me. I'd want a sea trial if speed is important.
- 5
Re: structural integrity compromised
I believe it, that 20hp merhatsu is an overachiever. I had a heavy 14' vee hull harbercraft with a 20hp evinrude. When I up sized to my current 16', I tried the 20 on it and it planed easily with me an two of my boys at an average of 225lbs each. 16' hull planes easier than a 14.
- 1
Thanks for your oppinions. Is the fish hawk considered a deep V hull? I have a bunch of windy high altitude lakes (6K ft) to fish, someone has o do it, and I have felt good about the response of the u14 Valco to the high frequency wave patterns and I dont know if the wider and longer Fish hawk will do as well as I have yet to get up close to a fish hawk's hull. I consider the Valco to be a deep V hull which went on plane quite well with my 15 hp Evi and eveen better of course with my present 25 Johnson. I would like a 16 ft deep V boat with 70"+ beam if I can get one within budget otherwise I will modify the middle seat of the Valco and stick with what I have. Thanks for you input.
Jerry
Jerry
- 1
An addendum, the Crestliner is a 1998 1650 fish hawk which has a beam approximating 72"
Jerry
Jerry
- 5
So I looked up the crestliner. Go look at that 1650. That's a chunk of a boat. It will definitely handle the waves better than any 14. However now that I've seen it and as much as I'm a fan of that 20hp Merc, I'd have to see it to believe it. The crestliner should be rated for up to a 60hp tiller.
In my opinion any boat you spend more than a certain amount on, you should test in the water. Any seller that won't agree to a water test ,especially if you offer to cover expenses if the boat is a ways from a lake, is a red flag. Maybe that 20 will push it good enough to make you happy and maybe it won't. I'd find out before money changes hands and you make a decision you regret.
- 4
The Fishhawk does appear to be a big water hull, high sides, and steady deadrise that goes all the way to the transom. Should handle chop a lot better.gpm wrote: ↑25 Nov 2021, 23:55 Thanks for your oppinions. Is the fish hawk considered a deep V hull? I have a bunch of windy high altitude lakes (6K ft) to fish, someone has o do it, and I have felt good about the response of the u14 Valco to the high frequency wave patterns and I dont know if the wider and longer Fish hawk will do as well as I have yet to get up close to a fish hawk's hull. I consider the Valco to be a deep V hull which went on plane quite well with my 15 hp Evi and eveen better of course with my present 25 Johnson. I would like a 16 ft deep V boat with 70"+ beam if I can get one within budget otherwise I will modify the middle seat of the Valco and stick with what I have. Thanks for you input.
Jerry
Honestly looks like that boat would be ideally matched with a 50 or 60hp. Those Deep-Vs take more power to push, and you want the speed on big lakes.
- 1
Weldorthemag and Giggles. The counsel is good. A test drive sounds like the right thing to do for sure but at this time of year where the boat is, water is becoming a solid. i just fiddled with the idea of buying the boat for too long and really hadnt thought about a test drive until you mentioned it. But, your right, there is enough money involved. I am not familiar with the concept of deadrise so will educate myself. "Ignorance, even when excusable, is not very impressive." And, deadrise sounds like something I need to know about. I appreciate your time and advice. Thank you.
Jerry
Jerry
- 4
Sure thing.gpm wrote: ↑26 Nov 2021, 11:24 Weldorthemag and Giggles. The counsel is good. A test drive sounds like the right thing to do for sure but at this time of year where the boat is, water is becoming a solid. i just fiddled with the idea of buying the boat for too long and really hadnt thought about a test drive until you mentioned it. But, your right, there is enough money involved. I am not familiar with the concept of deadrise so will educate myself. "Ignorance, even when excusable, is not very impressive." And, deadrise sounds like something I need to know about. I appreciate your time and advice. Thank you.
Jerry
Deadrise is the angle of the "V" on semi and deep V hulls. A true "deep v" will have a V that runs all the way from the bow to the transom, with varying degrees of angle. A Semi-V is angled at the bow but tapers to nearly or totally flat at the transom, a compromise between a flat bottom jon and a deep v. Generally speaking, the sharper the deadrise, the better it will cut waves and ride.
- 1
Ryan, I would love the stability of your boat as two of us will be fly fishing out of the Fish Hawk a lot, which is often done standing up, right, but a mile or so each way in fairly heavy chop in a flat bottom boat for a guy who is just slightly younger than dirt would be a test of his (my) sense of humor. It looks like the Fish Hawk may not handle the water quite as well as the Valco but I am hoping it will be a bit better as a platform from which to cast. Thank you for our interest
Jerry
Jerry
- 1
Giggles, thanks for your succinct explanation of "deadrise". On my own, It took me over an hour to get to where you got me in about 15 seconds.
This forum has been sooooo helpful. I have spent a lot of my life "in the thick of thin things" when I should have or maybe, could have been studying tin boats. I have spent many years in drift boats on blue ribbon water in Idaho, which water has become a bit too much like interstate 15 so I have, in the last 2 years turned almost exclusively to practicing the quite sport (fly fishing) on still water. Fewer boats but more motors. Oh. well.
Jerry
Jerry
- 5
1650 fish hawk is my dream boat. Or a similar 16 footish tiller from Lund, Alumacraft etc. I like the deep vees and flat floor rather that the bench seats in my current 16' naden utility.
- 1
Benches are a sign of a frenzied mind totaly devoid of imagination and appreciation for functional beauty. And you can quote me. My center bench has become intolerable. What more can I say.
Jerry
Jerry
