theyyounggun
I was out trying to flip my hitch but its stuck! Any ideas? #-o [-o<
lckstckn2smknbrls said:BFH and or the hot wrench.
ARFrogman Ladue said:Where do you live?
I see now. I would use an angle grinder to cut a slot though the nut and threaded part of the ball then buy a new ball. I use Master locks interchangeable hitch ball system.theyyounggun said:Ill post a pic if I can figure out how... But its not that its stuck in the truck. the ball is rusted together to the big nut and lock washer.
Captain Ahab said:Use the penetrating stuff as outlined above - let it sit for a few days (apply maybe 2x a day)
fender66 said:Captain Ahab said:Use the penetrating stuff as outlined above - let it sit for a few days (apply maybe 2x a day)
+1
Also, if you get a wrench with a longer handle, you can increase the torque on the nut...unless the whole thing is spinning when you try to loosen the nut.
theyyounggun said:fender66 said:Captain Ahab said:Use the penetrating stuff as outlined above - let it sit for a few days (apply maybe 2x a day)
+1
Yes. I was using a cheater pipe. I was using a crescent wrench that I use to change bush hogs blades on the nut and the teeth on a pipe wrench to grip the ball but it still won't move.
